H
houstoncajun
Hi everyone,
I have recently purchased a 1980 model and trying to identify the engine in it to redo everything and find the proper specs. The engine has been replaced with a goodwrench engine, the valve covers say "Goodwrench" and have "350" on them in red. On the block "boss" in front under the head on passenger side says "MI 18800" clearly. the block "boss" on the rear driver side that has the bellhousing connecting to it reads "3 or 8 1st then 97 then 0 or 6 then 010" . Another thing is that it has 43TS delco spark plugs in it, I thought those were only for the 305 ci? Is there any other way to see what it really is? should i pull the valve covers and find out what heads are on it too? If it is a 350 do i have to get real technical with the year block and all, or are all the 350's basically the same specs for tuning and parts? Any help will be appreciated ;help
