JHStevenson
New member
I have a 1988 4+3, rebuilt engine 20K miles ago (20 over, otherwise stock), with Hypertech Chip, Borla exhaust. Recently, while at light cruise, the engine has developed an irregular miss - such as when using cruise on flat road and at regular highway speeds (65 - 75). With any application of the throttle to accelerate, the miss disappears. Engine is operating at normal temperature, and it makes no difference with or without the A/C running. At WOT, car runs like it should, no miss and puts a smile on my face.
I have pulled the plugs, checked for wear- they appear normal, checked plug gaps – all properly set. Plugs and wires were changed at engine rebuild –stock equivalent. Timing was checked (used book procedures – pain in the rear) found to be spot on.
What should be my next step?
