1
1981
My 1981 is using way too much oil these days.
It is a daily driver.
All stock rebuilt engine.
Symptoms:
---> Does not leave oil on the ground.
---> Only blows white smoke during some start ups, if the engine was just run, then no smoke appears. The smoke is always present if the Vette sits overnight (about 12 hours). The smoke is like a big puff of cigarette smoke. No continuous smoking, this is not condensation, oil is being used.
---> Uses approx. 1 quart for every 200-300 miles.
---> Engine was rebuilt about 3 years ago (approx. 3,500 miles)
---> Was kept in storage during winters (approx. 6 months at a time) before I bought it.
---> Other than this the Vette runs great.
I do not know much about engines, but I would say that the valve stem seals are bad. Probably from sitting up in storage during winter months.
What do ya'll think would cause this problem?
Has anyone had this problem? If so, what would you recommend I do to fix it? Should it be a major worry right now, or do I have time before it "has to be fixed now".
Are there any Engine Oil Stop Leak additives that can be safely used without damaging the engine? I was recommended to use "K&W" to hopefully retore the seals. I really do not see how anything other than replacing seals could fix the problem with bad seals. So if this did not work I was going to then worry about the seals and replace them.
What do you think about this? Anyone ever used this stuff?
Thanks for the knowledge,
1981
Symptoms:
1981
