engine pulleys
atomicoupe
1967 Coupe
decided to upgrade to a Borgenson P/S setup
and Vintage Air . Trying to determine pulleys required
seems stock arangement was
2 grove pulley on water pump (short shaft)
3 grove pulley ( 2 piece ) on crankshaft
single grove for Alernator, P/S pump and Air Compressor
would like to use stock setup
any help in finding the pulleys (part no.s , similiar type replacements etc.)
thanks
Steve Fiore
after much research ,found the stock part no.s
in a Assembly Insrtuction Manual
purchased all required pullies from Summit Racing
using Vintage Air for price matching
I was having a hard time getting pulleys to line up on my '69 truck project and it appeared that the ones on my wife's '81 Corvette would be perfect so I bought a p/s mount and pulley and others to match. Turns out I had an alternator mount and pulley that matched also. I figured that if I copied the '81 completely it had to work. You can't go wrong using all of the correct part numbers for the same application. Good choice grabbing those 1967 part numbers.
Tom
