A
AUSSIEVETTEMAN
Well, I have decided to do it. She goes in on Wednesday to have the engine pulled and sent to the engine rebuilders.
The guys that are doing the rebuild are true blue GM/ Chevy guys and have been doing their stuff for over 20 years commercially.
Although I am not in favour of boring a matching numbers block, a slight skim probably wouldn't hurt and will return the cylinders to 'true'.
They are:
Boring the block 20 thou over
Balancing and blueprinting the crank
Installing stainless steel welch plugs
Painting the engine chevy blue
Installing a 'Larry Perkins' internals kit - New oversized pistons, rings and bearings. Larry perkins is an Australian V8 Supercar driver and Automotive Engineer who operates a shop simular to Lingenfelter, without the twin turbo stuff. His gear is top notch and is lighter than stock.
Installing bigger valves - don't quote me but 1.6 inlet and 2.02 exhaust
Installing a heavy duty timing chain
Installing a bigger cam and push rods and lifters to suit (not too lumpy)
Installing a set of roller rockers - Street Terra from Yella Terra
This will be matched up to the already installed Edelbrock Performer inlet manifold and Edelbraock QJet 1903 795CFM carb.
OK, she won't be a big power house, but I think she will run for a long time and hopefully for another 20 odd years, when the only thing I will be driving is my 'missus up the wall'! :L
I will miss her, as she will be gone for around 2 to 3 weeks. :cry
What do you guys think or do you guys have anything to add?
Tony
They are:
Tony
