Doing it as a one piece assembly is best. However, you have to get a cherry picker that is extremly long and low slung to pull it off. Most are not built to handle it.
So, pull the radiator, and front core support after unhooking the drive shaft, mounts, exhaust, wires, heater hoses, fuel lines, computer plugs, gear shifter, clutch rod.
Now, build a reinforcement in your attic and use a chain hoist from above. You can work in conjunction with a friend. As you lift the engine, roll the car backwards.
Mark the spot where you started (the tires on the floor) so that when you are ready to put it back in you can reverse the procedure.
If you can't do that, and only have access to a normal sized cherry picker, then you will have to pull the trans out from underneath, and lift the engine from the top, but you will have to reach in over the side of the fender instead of the front of the car.
Good luck!
