Help! Engine vacuum lines diagram.
PEAHAT
Virginia
81 c3
I am having confusion between Dr. rebuild and shop manual diagrams, does anyone have any real clear actual pics? where does the line off the air cleaner actually plug into? Does any line plug into the back of the carb on top? This is a manual transmission car.
Scott
Virginia
The line off the air cleaner goes to the upper left port (when viewed from the front)
I believe there should only be one port on the back of the carb, (other than the vacuum line to the brake booster) and it's at the bottom and goes to the vacuum sensor.
If you still want pics, let me know and I'll take some for you.
