C
corvettecrazy
sometimes they work and sometimes they don't what could be the cause of this??? the flashers always work and when the turn signals dont work the clicking and lights on the dash dont come on either.
c4c5specialist said:HI there,
The principle is this. Your brake lights, your hazard lights, your turn signals, and part of the daytime running lights are all channeled through your hazard switch.
This is why your hazard switch will function correctly when you enable it. However, the rest does NOT.
Another check would be to test the following. When your car is off, turn the left signal on, then turn your hazards on. If your left signal does NOT flash, this circuit is ok.
Then, turn on the right signal. If the right signal does NOT flash when the signal is on, then you found out the problem is NOT the turn signal switch, it is your hazard switch.
If you step on your brake pedal when your hazards are on, and they stop flashing, but are still illuminated, then you know the brake light circuit is ok.
Allthebest, c4c5![]()
