mlm0
I replaced a broken EVAP canister on my 1989 corvette. The problem is that the new canister does not have the one  connection on the bottom like the original. I think this connection was for a fresh air intake to the canister, but not sure. The new canister instructions has a fresh air intake on the top, with a splash cap on it. The instructions advise to just plug off the hose that connected to the bottom of the original canister. When I pulled of this hose to plug it, it disconnected from somewhere going to the engine I guess. Its a rubber hose connected to the bottom of the canister and then becomes a " Y " rubber connection.The problem is that I can not find where to  connect the two ends to leading from the canister going toward the engine.  can anyone help   thanks  Mike
