G Winter
Started work on my new exhaust from the cat back. Got the pipe done now need to work on a couple mufflers.
The pipe is 3 in OD 304 food grade stainless. I bought some elbows we use at work and cut them to the right angles. laid everything on top of the old pipe and matched it all up.Tacked it together took it home and was a perfect fit.Fired up my Tig at home and welder all up. I made the flare on the lathe at work,used a bearing on a shaft in the tool turret and beveled it out. Total cost of this so far is $16 each for three elbows plus about 10 cents a lb for 40 in of scrap pipe pieces. Maybe 20 lbs . Hope I don't drop the back pressure to much and lose the bottom end power.
The old
The new
Glenn
![Wave :w :w](/data/assets/smilies/savewave.gif)
The old
The new
Glenn
