69MyWay
Okay guys, you are batting 1,000 so far with all your help on bringing my 85 back to life.
Here is the next problem.
Granted there is still a bit of 2 year old gas left in the tank messing up the mix...but...the car just won't start!
What I mean is, I spin it over, and over, and over, and over, and after a while of turning it on, then off, then on, and spinning it over, it will start to combust. If I hold the starter engaged, the motor will eventually pick up and fire and run on its own.
As soon as it starts....I am home free.
It will restart within a few minutes of the original running time. However, if you wait more than five minutes, it won't start.
I have to squirt a tiny amount of starting fluid into the intake (I just shoot it in the power brake hard line), and it will fire immediately, and run fine..no problem.
So......What gives?
If you suggest fuel pump...where the heck is my fuel pump relay? I am still waiting on the manual from the prior owner. I should get that this weekend.
I am getting a code 36 (MAF relay burn off problem).
I am getting that after it is warmed up and I nail the throttle.
So......What gives?
