Jimailer
I was reading on another forum about a guy who took his 05 F-55 in because he couldn't tell if it was working. After much fighting with the dealer he got them to ring out the wiring and they found a missing wire from the switch to the computer. Does anyone know of a sure fire way to know and test that the system is working? He said to push down on the car at a finder then switch to the other setting and you should feel the difference. Does the car have to be running? Does it need to be moving for the sensors to work. Does the push on the car thing really tell if it's working? Would someone else try it and see if you feel the difference I did not.
I keep it in tour most of the time but if something is not working right I'd like to get it fixed the system was not cheep
