toolman0114
$28,000
1974 Corvette coupe
All redone, body-on restoration.
Fresh custom paint job, Ruby red pearl metallic with ghost flames on hood and fron fenders.
Rear Turbo wing
Front Indy spoiler
Fibreglass front & rear bumpers
Side exhaust & headers
New leather seat covers, carpet, dash pad,
all gauges work
original am/fm radio
Newer BF Goodrich tires on aluminum YJ8 rims
extra set of factory rally wheel painted to match the car with older set of tires mounted on them.
New brakes, new rear O-ring callipers & rotor, rebuilt front callipers with new rotors All new brake lines & hoses
Rebuilt (with genuine GM parts) Muncie M20 4-speed
Rebuilt rear end
new fuel tank & sending unit fuel lines, and fuel pump
new vacuum system, lines, (2) headlight relays, (2) actuator canisters
All new front end parts, tie rods, ball joints, pitman arm, swing arm bushings
New power steering valve & piston
New rear anti-sway bar,
4 new bilstein sport shocks,
new rear adjustable strut rods
Fresh built 355 engine, only thing original is the block. - 10 1/2 - 1 compression, speed pro pistons
- Holley street dominator intake
- Holley 650 street eliminator carb
- 65cc Cast iron Dart Heads
- scat rods
- Eagle racing crank
- Zoom clutch
- 1.6 full roller aluminum rockers with stud griddles
- high voltage electronic ignition
- high volume water pump
- double roller timing chain
- comp cam -
tall welded aluminum valve covers
- new chrome alternator
- new high torque mini starter
- 7 quart oil pan
- high volume oil pump
Car has 98000 MILES
Runs and looks great
Mint condition
Approx $50,000 invested in it
1974 Corvette coupe
Rear Turbo wing
Front Indy spoiler
all gauges work
Rebuilt rear end
- scat rods
- Zoom clutch
- comp cam -
- 7 quart oil pan
Car has 98000 MILES
Mint condition
