F/S: 1993 OEM Machine-Finished Sawblade Wheels/Tires (PA)
4CAM LT5
Blue Bell, PA
1991 Corvette ZR-1
Price Reduction: A full set of four 1993 OEM Machine-Finish Sawblade wheels, and OEM Center Caps.
2 - 17" x 8.5" Fronts and 2 - 17" x 9.5" Rears, with 56 mm offset. These wheels were standard on 1993, 1994, 1995 and 1996 Corvettes. Wheel set will fit ALL '88 and later Vettes. All original GM markings on inside of each wheel are visible (see photos of back-side of wheels).
Front wheels have 255/45 Goodyear GS-C tires mounted. Rear wheels have 275/40 B.F Goodrich Comp TA ZR tires mounted. All four tires have good, no-scuff sidewalls, and plenty of tread remaining.
Wheels are not perfect, with some clearcoat peel and a small bit of rash. Could be re-finished easliy. This well-balanced set of Classic Sawblades would make a great set of "second" wheels/tires for winter or track.
No delivery. Must pick-up in West Chester, PA
The first $600 in cash will do the trick.
4CAM LT5
Blue Bell, PA
1991 Corvette ZR-1
Bump...For Price Reduction...!!
