Fan Clutch - Is this bad?
Norcross, Georgia, United Stat
2017 Arctic White Grand Sport
I took the fan clutch off as part of a water pump repair and placed it with the shaft that attaches to the water pump down. It sat in the very hot garage for about a week. I picked it up today and about a tablespoon of the liquid inside had drained out.
Do I now need to replace it?
Bob
I would suggest loosing the clutch and installing an electric fan. I dyno tested my car with and without the fan clutch. I picked up 13hp and 17 lbs-feet of torque. I did not spend tons of money on the conversion...picked up a used 16" fan and made a mount from aluminum stock at home depot. With wiring harness the entire project cost about $100.00. Best money I have spent on the vette. Being that you are from Norcross.... GO DAWGS!!!
80 Convertible (the car I wish I had :D)
Do you have any pics or details about the conversion? My fan clutch is in need of replacement, and I was thinking electric, but no idea how to do it.
Where did you pick up the electrical, & what turns it on & off?
Steve :w
Just get a flexfan. You'll get differing opinions of them here (mainly due to safety issues), but mine works flawlessly and looks good to boot! Simple repalcement and will have you up & running in no time.
sac001,
I got my fan used from a used race car parts store in nascar country...charlotte, nc. you can get a 16" electric fan from summit new for cheap. I pulled the radiator shroud ( which opens up my engine compartment) and made a mount for the fan using the factory shroud mounts. I then ordered a Painless Wiring electric fan wiring harness that came with a water temp sensor that installed right into the manifold. The install looks factory and brings my engine up to modern standards. As I previously posted, my car picked up considerable power on the dyno by removing the fan clutch...also probably picked up a little better gas mileage. Another by product is that it is safer to work on the engine while its on...no fan blades. The engine bay looks better and I don't have to mess with the fan shroud. My car has never...ever exceeded 185 degrees...even on the hottest days in charlotte, nc during the summer. The entire project cost me about $100.00. Good luck either way.
