Fast Turning Signals
Frankfurt/Germany
1982 Collector Edition
Ok, today must be confuse driver day.. :W
Yesterday, driving home, all is well, turn signal wise. All are a-blinking as they should. This morning, i make a left out of my street and it's blinking fast. Ok, methinks, bulb blew, no biggy..
So i finish driving to work and notice that both are doing the fast blinky.
ok, maybe not the bulb.. :confused
So, i check once i park the car, and all corners are a-blinking as they should, just double speed.
Is the relais on it's way out and i am getting a head start? It was replaced a few years ago and has been blinking away just fine..
Any thoughts/advice are appreciated..
Tia!
:w
-Stefan
PS: Maybe i should give it decaf in the morning ? :L
Tia!
:w
-Stefan
Could be the flasher going bad or it could be a Ground not getting a good connection!!
Was the head lamps or park lamps on at the same time you were using the signals???;shrug:confused;shrug
:upthumbs
mine did the same, replacing the flasher unit behind the passenger dash pad solved the problem.:beer
Junkie: I tried it with both the lights on and off.. No change, with the lights off or on.
Howard: Thanks, i'll take a look and see where i'll get one here.
:w
Ok, as suggested from the local Vette crowd, i swapped the turning signal relais with the hazard one and (drum roll please): Working like a charm. I found a replacement, but it's a square, not round. mmpff..
So, for now, i will leave as is, the turning signal is fine now and the emergency flashers are slightly bit faster, but wont annoy as i hopefully wont have to use them. :)
Btw, they are in the drivers side fuse bank on my 82.
Howard: Maybe they moved them between our years ?
:w
-Stefan
