HI there,
Lets get technical.......
The code 23 is ok, as this code will flash if you cycle the key 3 times without driving the vehicle, on and off.
As for the 32, this is for the right front shock absorber out of position. So, heres what you want to do, as a quick check.
Pop the hood, and removed the inner fender on the passenger side. Then, look at the shock, the black motor is at the top of the shock. There is a retaining clip, which holds this motor on top of the shock, remove it. Then pull the motor directly up, you may have to wiggle it a little, but it will come out. Look at the top of the shock, as this will look like a spline. If you can turn it about a half turn, and thats all, you are ok, and the motor is most likely at fault. If there is chips in the splined shaft, or you can turn it one full turn, the shock is no good, and should be replaced.
Please let us know how you make out, c4c5
