favor from a 1984 corvette owner needed
topless82vette
southern california
1982 convertible (not factory) stock 350cfi auto
can someone with a 84 that still has it's original thermostat housing post a picture of it for me, or if you can tell me kinda what it looks like it would help me alot, I know theres a difference between a 82 and a 84 and a 84 vette upper radiator hose is the only molded one I can find that will go around the back side of my alternator and still reach the radiator ( because I put a camaro serpentine drive on it) only problem is my thermostat housing still causes a problem & do you know if the 84's thermostat housing will fit the 82's crossfire manifold
thanks
Jeff, did you ever get the picture you sought? :confused
_ken :w
I have an 84. I am trying to doctor up a picture for you. Give me 5 minutes.
Sean
I replaced my thermostat 3 weeks ago. All I had to do was remove the Air filter and it exposed the piece that holds the thermostat. Mine was at the end with the red circle around it at th e end of the chrome braded hose. I hope this was what you were looking for. I am not a mechanic, but I am learning!
:L He may not be able to see the thermostat housing, but that sure it a pretty L-83. :upthumbs
_ken :w
84 intake picture
I hope this is large enough to see the detail.
Excuse the mess, this is a work in progress.
Ken
different than the '87
I imagine so.
Try putting this intake together from scratch.
There use to be a Holley and Edlebrock intake on this engine.
Talk about a learning experience.
Ken
Looks like you're coming right along though; it won't be long before you're out there cruisin' and wavin' with the best of 'em. :upthumbs
_ken :w
kmc
congrats on getting it back together by the way, it sure does look good .... here is a website of a really awsome looking cfi engine compartment on a 82
http://www.hoepfner.net/vette/
does this thermostat housing outlet come straight out vertically the problem Im having is mine comes out horizontilly towards the alternator
Thermostat housing
Thanks, it's been a real pain trying to track down all the parts.
The housing points up at an angle (30-45deg)and towards the valve covers. Standard for Chevy 350
Ken
