D
drwikboz
Well,
red70vette said:I agree with the junkman. If your brakes get spongy shortly after being bled then you have air getting into the system. Run out in the rotors are one potential culprit but it would help if you knew what was done with the prior brake job. Did they do pads only? New seals? New sleeves? New Calipers? Rebuilt calipers? Who did them?
red70vette said:If the entire system is new find out who did it and bring it back. That is not how a brake systrem should work if it was recently overhauled. Something was not done right. Get it done right, brakes are something you want to work properly all the time.
drwikboz said:Thanks all. Unfortunately for me I only get to play with the Vette on Sat & Sun as it stays at my family's house, but I will take all of the advice given and will post a reply as soon as I've fixed the issue.
