C
CAJUN C4
How many of you have installed the Fidanza Alum. Flywheel ? Any Noise issues? I heard of some potential ones.?
CAJUN C4 said:How many of you have installed the Fidanza Alum. Flywheel ? Any Noise issues? I heard of some potential ones.?
96CERon said:Yes you must match balance to the old dual mass flywheel! Yes I would do it again. I hated the dual mass design(39 lbs etc.) and the concept of same. It was a bandaid to fix a transmission design problem. I have no engagement problems
stgry1 said:IMO you're defeating the purpose by getting a steel FW. Might as well just replaced the DM. If you're doing it for performance and weight loss then stick with the AL. IF cost is your motivation then Steel would be an option. I'm surprised to hear everyone talking about balancing issues. You talk to the sellers of these parts and they will tell you that about 10% of people have vibrtion issues. Most have a clean install. I've tried to get people down here to match balance the 2 flywheels but can't find a machine shop willing to do it or able for that matter. Good luck in your hunt.
You could be 100% right but what the heck can you do? I want the advantages of an AFW just like the next guy WITHOUT the vibration. If you can't get a shop to do it locally, then you need to send both pieces out. By the time you add up freight both ways plus machine time PLUS shop time while the vehicle sits and waits for the parts....man I tell ya. It adds up quick. PIA!!! I still might roll the dice with the Fidanza..if I do i will post back.Vettelt193 said:I think the 10% number is BS.
stgry1 said:You could be 100% right but what the heck can you do? I want the advantages of an AFW just like the next guy WITHOUT the vibration. If you can't get a shop to do it locally, then you need to send both pieces out. By the time you add up freight both ways plus machine time PLUS shop time while the vehicle sits and waits for the parts....man I tell ya. It adds up quick. PIA!!! I still might roll the dice with the Fidanza..if I do i will post back.
