It was pretty obvious after it was fixed, but it had baffled me a couple of years. It had gotten much worse over the last two months.
I had purchased a replacement battery a couple of years ago. I kept getting low voltage warnings, flickering headlights, etc. I finally decided to replace the battery again a few months ago. The problems continued, including the dreaded column lock, activation of the fuel cutoff, etc.
It turns out that the holes in the side of the new battery are slightly shorter than the bolts that attach the cables. So I could torque those bolts down all I wanted and the connection was still loose. The mechanic used some new bolts and ground off a very small amount off the end and reinstalled the cables. The gremlins are gone.
I hope the rest of you are better mechanics than I am. Oh well, live and learn. :L
