03WhiteConv
- Joined
- Oct 8, 2008
- Messages
- 16
- Location
- Texas
- Corvette
- 2003 Speedway White Convertible, White/White/Red
I had a P1415 come up the other day and thanks to the good folks here I've replaced the check valve and the code went from C to H! So, I was driving it pretty hard yesterday and noticed that in 1st gear at the top of the RPM prior to shifting the engine had a slight knock and the power just wasn't what it should be. Shortly after that the check engine light started flashing and then the light went out. I had just reset the trouble code on the DIC that day and when I check after the flashing light, there were no new codes.
Any thoughts on what that flashing light means? The car has about 30k miles on it and is still bone stock.
