Brian Smith
Just got my 1993 LT1 out of the paint shop and the display, where the fuel mileage data etc. is displayed, has started flashing "Sys" while running. Once it starts flashing it flashes once per second for three cycles and then the normal display starts back up and at an undetermined interval it will start again with the same rep rate.
The only thing that has changed was, while the car was being painted the painter located the driver door security electrical pickup (coil?) that goes on the door key lock cylinder post. It was dangling down in the door somewhere. It is now back where it belongs and plugged into the appropriate connector. Also found the Driver PKE door mounted antenna connector dangling and re-attached it to the proper connector on the antenna.
Eight months ago I replaced the missing fob from that outfit down in Austin Texas and tried to configure the PKE system to work properly. It never did work properly and saw some posting on the internet compaining about that firm and their inability to do the right thing. Now given that I approach the car from the drivers side and now know the receiving antenna was disconnected and the coil on the lock wasn't in place maybe it was working as well as one could expect.
I know I have many variables at play here but the starting point is to determine what triggers that "Sys" message next to the tach. I reviewed the factory manual at some length but as you guys know there is much data there and it is easy to chase the wrong rabbit down the wrong hole.
I'm not sure any of that other mess I mentioned has a role in all this but thought I would mention it and ask if any of you old technical hands have tripped across this before. Thanks in advance for your kind consideration.;help
