anniegreensprings
i'm in the process of replacing the flywheel, clutch, throw-out bearing and pressure plate on my 1992 Coupe. they are all genuine GM parts, no after-market. can anyone tell me for certain if the new flywheel is already balanced and can just be bolted on, or do you have to remove weights. or is the flywheel and cranckshaft balanced as one from the factory. i would like to make sure before i start to replace everything. i really don't want to end up with a vibration after all that work. thank you for your time
