Andries
Hi, can somebody please explain the fog light wiring of a 1993? I've opened the switch and found purple, yellow and a lighter yellow/white-ish cables. When I switch the headlight on I get 12v on the yellow/white-ish cable, then if I switch the fog light switch on I get 12v on the purple and yellow cables. What I would like to know is where is those two wires going? I need to wire a foglight on for the back because of British MOT so are hoping I can get a supply from that switch inside the engine bay and run it to the back, using one of the reverse lights with a red bulb in it. My Corvette was a export model, so it does not have the front fog lights anyway, but i'm hoping the wiring will still be there. The other problem is I need to do a opti change this weekend, but there is enough threads on that issue to help me My corvette was starting and cutting out on 180-190 temp, but now it is not even starting, throwing codes 16,36,42 (opti gone).
