J
JJCP
Fog lights both out??? Center light in fog button no on either
I just bought a 98 and neither of the fog lights were working. I assumed it was the fuse. I replaced the fuse in the box inside the engine and they still don't work. I then noticed that when you push in the fog light button on the dash, the little light in the center of that button does not come on to indicate that the fogs are on. When you push the fog light button, I notice it does make sort of a clicking sound at the fuse box in the engine. Does anyone have suggestions on what might be wrong or what else I might need to try checking. Maybe the switch itself is bad (although the trunk release still works which seems to be on the same switch). Maybe both bulbs are just out, but would that cause the little light in the center of the button on the dash to not come on anymore? Please advise of anything I can check out. Thanks!
