topless82vette
- Joined
- Nov 1, 2001
- Messages
- 910
- Location
- southern california
- Corvette
- 1982 convertible (not factory) stock 350cfi auto
hopefully one of you can answer this Ive got a coputer realted problem with my 82 but no codes in the computer so naturally its maechanical or bad electrical connection heres what the car does stumbles very bad at idle and jumps in and out of closed loop mode (technical for computer stops commanding fuel mixture) and has a extremly bad odor out the tail pipes and will use a 1/4 tank of fuel within two hours of idling however no fuel leaks anywhere and catalytic converter turn orange after say 15 minutes at 2000rpm car has plenty of power so Im sure the cat and exhaust aint plugged anyways heres a few possible problems Ive found
(1) ecm wires coming from motor go to fire wall and there is a black plastic cover that covers them problem here before the harness connector looks like wires have been cut since there is alot of electrical tape is yours like this ?
(2) prom chip number in mine is 9531 ecm service number unknown at this time do any of you know what it should have ?
(3) wire harness that goes directly to the starter motor has a connector mine is somewhat melted down .... could this be a problem ?
(4) ecm's coolant sensor at front of intake manifold wires were cut and a different sensor installed did this type of sensor on my trans am with no after effects its just a upgraded sensor ... but do wires have to be hooked up a certain way and could this cause my problem
(5) thermostat is some kind of a GM unit but no temperature data is on it here are some numbers of it has on the top it says ac delco then 54 after it, at the bottom under the spring it has the letters hrd inside where the spring is it says 2/3 Im hoping the thermostat is a low temp unit thus causing the car not to get to operating temp and causing this problem since it would be a easy fix
