Peer81
Hello everybody,
A new thread about something I'm trying to do. I don't say it will work but it is also fun figuring things out.
What is the case. I have a all original L81 computer system with the original E4ME Qjet carb. I don't want to change to a easier carb but I want to change the old ecm for a better (later) one. Other cars featured the E4ME carb more years then the vette so I found out the last car with a E4ME carb was a 88 Monte Carlo (SS).
So I bought a 1228079 ecm (from a 88 Monte Carlo) which also can be found in 87 camaro's and caprices (with the E4ME carb engines). I also have the bin files for the ZZ4 upgrade that ones could be bought for the camaros. This ZZ4 bin file can be burned on a prom that works perfect in the 1228079 ecm.
Some complications... The new ecm has some extra functions (it controls the 700R4 I have so that is great) but it also need a electronic spark control with knock sensor and some other stuff.
Right now I'm comparing the ecm terminal in and outputs to see what the difference is between the 81 and 88 wiring harness. Some wires changes place and others went and new ones came in. I also have the full 88 ecm wiring diagram and the 81 ecm wiring diagram to compare them. Next time I'll show some pictures what I found.
But first a simple question to start with..
After digging into the shop manual many times I found the 88 has a baro sensor but I can't find it in our 81 wiring diagram. Does anybody know if an 81 has one? In the 81 shop manual code 32 is a "baro sensor circuit low" but I can't find it..
On page 6E1-44 all sensors can be found. I see the vacuum sensor (against the firewall) but no baro sensor. If somebody knows please let me know
Groeten Peter
Groeten Peter
