from Super Ram to Stealth Ram, do/dont
  • Thread starter Thread starter Igor
I
Igor
Hey guys.
Took apart the corvette. It has a super ram intake on it with a ported base and everything. The TB looks like a 52mm ported one.
Needless to say I loved the removal of the intake. 3h well spent :bash
The Stealth Ram is 300 bux. It is not so bad. I am considering buying it mostly due to the fact that my super ram is not in the best shape any more (R&Red a few times). But I am wondering if I can run the same TB as on the stealth ram? It says in the instructions to run a lt1 stock TB. I do have one of those, but its only 48mm and my motor needs more I think.
Would the fuel rails fit from the Super Ram onto the Stealth Ram?
Any other benefits?
Motor is a 400" with a 220-230 flat tappet cam. Auto car with 3k stall and 3.08s.
Thanks.
Are you talking about the Holley Stealth Ram? According to my Summit Racing catalog, the Stealth Ram won't clear a stock Vette hood.
It won't fit without a new hood, or scoop. The fuel rails don't work either. You'll also need a different fuel pressure regulator. Try putting studs on the upper plenum, it's way better to work on!! Use kept nute with the intergal washers, and it's a breeze.
