wildbill85
Active member
Hi, need help with the front brakes sticking on a 85 c4. I had a earlier post with the same problem and I thought I had it fixed. I replaced the front brake pads as the old one's where shot. I can drive the car one time with on problem at all,but on other times the front brakes start to lock up and get really hot and start to smoke. I was told by someone on this site that it sounds like the master cylinder was going out. If you were to look at my master cylinder it looks in really good shape.(new looking) My one question before I go and replace the master cylinder can you bleed the master cylinder??? or should i just go a head and replace it. Any tricks or help on this brake problem would be very appreciated. Thanks. Bill
