69MyWay
Here is some step by step for those that are either curious, or considering removing and installing the C3 front clip.
This car has gone through some massive reconstruction in the last year. We have replaced the entire bird cage and frame. It is getting the same body treatment as killer in a coupe version.
This first pic is where I was taking measurements and preparing for the bonding.
There is a triangle mount flange made of fiberglass that rivets into the upper cowl in each lower corner of the windshield area. Those of you with water leak problems most likely have a huge rust hole under this area. In this first picture I have not yet installed the triangle mounting flange.
