- Thread starter
- #21
69MyWay
The driver door gap was actually too tight on the front edge, and was missing the upper part next to the winshield and door. So, using a variety of hand shaped tools and methods, we re-create the upper portion of the fender, then open the door gap by using the same paint paddle wrapped in 80 grit. By sliding this in and out of the gap, up and down, the passenger and driver door gaps end up being exactly the same (much less than they did from the factory).
No, to get the perfect as if the front and doors were once once piece, and a gap was simply cut to make the door open, the next phase is to feather fill the two panels, then long block inbetween/across the door gap until both are exactly the same level.
