goingballistic
I purchased new bushings for the front end, upper and lower A-Arms.
Question, for obvious reasons the removal is not as straightforward as one would assume, if you are doing the top (or bottom for that matter) what happens when the bolts are removed? Does the car drop in other words do certain parts have to be jacked prior to releasing the bolts. I'm leery to pound them out and then have something settle and not be able to replace the bushings or bolts.
Any suggestions, I'm trying to get this done before I drop in my new motor.
Thanks.
Thanks.
