MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
Well, I decided that, while I have the radiator out, I should replace my (shot) front bushings. (I'm going to kill myself with the "while I'm at it" stuff, but that's another topic, I think...)
I ordered the polyurethane "deluxe front suspension rebuild kit" from Zip ($180 on sale). It comes with upper and lower ball joints, upper and lower control bushings, outer tie rod ends (two left and two right), two sway bar link kits, and an idler arm.
I'm not sure what of this I can do myself, since I don't have many special tools, and I don't want to mess up the alignment. I'm going to have it aligned after everything is installed, but I need to maintain the alignment during the parts that I do. That way I can drive it somewhere to get the final parts (if any) installed, and the alignment checked and corrected.
So, the first question is: what can I do, as far as tools go? I need to do the upper control arm bushings myself, since those need to be done with the radiator out, from what I hear. It looks to me like I'll need a spring compressor, to take the tension off the system. But maybe there's another technique? If not, I'll have to borrow one. Anything else that requires special tools?
The second question is: at what point during the installation do I mess up the alignment? I want to have it at a shop that can re-set the alignment, before I change out any parts which will knock the alignment out of whack. If not, I'd be stuck trying to drive it, while mis-aligned (and this is Maine, so we're talking driving it a good distance to get to the nearest alignment shop).
Third question: any tips/tricks to making this go smoothly?
Fourth question: I assume that, at some point, the grease will dry out and the poly bushings will start squeaking a bit more. Is there any easy way to replace the grease and quiet them down again? Not a huge problem - I just think it's nicer when a Corvette growls than when it squeaks...
Joe
Joe
