front turn lamps lenses
cscarlson
SYRACUSE ,UTAH
2003 50Th Corvette
has any of you blackout your front turn light lenses , i ahve some you install but it looks like you have to jack the car up to get them on
Well it might help to reach in there. Problem is just getting the tool under there (mine's only about 4" off the floor). But its not hard to do, its like three screws if I remember under the nose. Pull back the splashguard and reac up into the front.
The lense is held onto the carrier with two 10mm bolts. The carrier is just held in with a spring.
so. . .
Get access from bottom three screws.
Unplug the lights.
Reach up and unhook the spring.
Drop the carrier down through the bottom.
Remove the lense from the carrier.
Put it all back.
