M
mikejpss
Took my 81 for a spin around the neighborhood, upon return of the 5 mile trip I noticed the pass. front wheel well had slight smoke coming from it. Touching the wheel center cap indicated heat, but when I spat on the rotor it steamed. Doing the same hi tech test to the driver side rotor proved it to be cool as a cucumber.
Last month I noticed brake fluid on the inside tire of the pass. side. Is the smoke problem as obvious as it seems, that is, the caliper has failed and rides the rotor generating the heat- OR- is the smoke an indication of a bad wheel bearing?
I know theres tons of knowledge/experience here on this forum. Thats why I came here to ask before I take the jack and tools out the shed. Thanks for any and all inputs.
Happy Thankgsgiving to all , and especially to our troops in harms way.
Mike J.
Mike J.
