Vettehead Mikey said:...both sides of an issue when a poster is asking for suggestions.
The 'other' side being... it's a "Bubba pump" with headaches?
Vettehead Mikey said:pqtr -as usual- has missed the mark in his response and done nothing to answer the question.
The question was how to change a rubber hose given a full tank of gas. You and your friend response to 'how' was to label Holley pumps and rubber hoses and by implication anybody who would use them as "Bubba". And somehow I am the one that 'missed the mark'? :eyerole
The original question was fully answered by Mac. For the record I was not attempting to answer the original question - I was providing fact based clarification to the mis-placed 'bubba' commentary.
Vettehead Mikey said:My objection to this [...snip...] yet has the draw back of being difficult to install with respect to the need to create customised inlet/outlet fuel lines.
This comment leaves me confused. :confused If you read the original question very very carefully - you will notice that the 'Bubba' Holley and 'Bubba' rubber hoses are already installed. Docmacs77 somehow overcame the headache challenges you've outlined above and adapted the Bubba pump - So then where's the headache? :confused :confused :confused
[On a personal note, while I can't speak for others - I am one of those whackos who actually ENJOYS the challenge of customizing a configuration. I say bring on the 'headaches' if this is what you call a headache! And let's talk 'performance' on this performance forum]
Vettehead Mikey said:I share John's concern that indescriminately adding flexible rubber tubing held with hose clamps on the pressure side of the system is just asking for trouble. An OEM designed and purpose built hose is one thing, a do it yourself add on is another.
While I appreciate all the concern you've shown Docmacs77 with your bubba comments - Perhaps you know more about Docmacs77's installation configuration because I certainly can't speak for how "indiscriminately" Docmacs77 installed the rubber hose(s) and clamps. But I can assure you of these two facts:
A) The aftermarket low pressure rubber fuel hose has the EXACT same SAE stampings or superceding stampings as your "OEM" rubber supply side fuel hose.
B) The aftermarket screw clamps commonly used are as good as or BETTER than the spring clamps many OEMs use on the supply side rubber fuel installations.
