Well I am open to any and all suggestions. I would like to know what injectors I should buy. What about the pink tops everybody talks about? Any part numbers?
I know I am going to get 30# but I am more interested in brand?? I have heard accel's are junk, but everyone talks about the pink tops. Just exactly what are the pink tops?
I have Accels in my 76 it was my daily driver for 4 years with over 30,000 miles on it with no injector related problems; I must have gotten a good set.
Accels have gotten a bad rap. A lot of folks put ones that are too large into their engines. Without a custom tune, the engine runs like ****. They blame the injector instead of themselves.
If you size the injector properly, Accels will work just fine. Goes for any other major brand out there.
I believe there is a site where you can figure out how big or small injector you need. Does not come to mind right now. Help someone!
As lt4man said...a change in injector flow rate MUST be compensated for...either in a change in fuel pressure or updating the PROM accordingly (preferred). It'll run like crap if not.
I am sure we would all be surprised if we found out just exactly how many injector manufacturers there were. A lot of stuff is re boxed and sold under a different name.
Thanks everyone for your suggestions. I ended up order the Bosch/Ford injectors from Summit. They should arrive Monday. I am gong to start another thread with questions about the install. Basically any advice.
I was also wondering about the lube you put on the o-rings when you slide them into the intake??
