D
doclarry
Hi guys,
Thanks for the tips on my won't start when hot prblem. After reviewing all the possibilities it appears that the fuel injectors leak.
So, should I have the current injectors cleaned?
Buy new factory injectors.
I read about some aftermarket injectors that are much cheaper from Ecklers are they as good as factory/ are there other options ?
How much should a reasonable mechanic charge for the labor.
While doing the injectors is there any obvoius preventive work that should be done at the same time the car is dismantled to get to the injectors/ 56.000 runs great no leaks.
Thanks again for all your great advice. (I love vette people)
Larry Stemp
VETNUTS 88 35th
Larry Stemp
VETNUTS 88 35th
