HuskerNation
Hello,
I have an 89 Coupe 6 spd, I drive about 6-12 times a year and while this year I have driven it quite a bit more. The vette is all stock with 71k miles & have owned my vette for over 10 years. Recently had an issue where it is dying, cutting out, rpm dropping, rough idle and when racing up engine too, at start up idle fluxuates between 300-1200rpm without touching the gas pedel. Once in a while it seems to be running fine but is way down on power. I also tried the a-b jump wire and only got the 12-12 handshake code. Also never have I gotten a check engine light to come on, at any time.
Actions I took: replaced the fuel filter, fuel pump and ignition coil. no effect by doing these.
One odd factor: when I initially had this problem I was on a drive and managed to get it home. Once in the driveway I was racing the engine up thinking something had to just get "blown out". I immediately pulled the vette in the garage & turned it off. When I opened the hood it looked like I was getting a little bit of smoke, almost steam like coming from somewhere around the distributor. I cannot find anything burnt, melted or the like, nor could I pinpoint a source then or now. I dont know if this has anything to do with the problem but I wanted to mention it anyway.
Finally, as much as I would like to be, i am not a mechanic. I try and often succeed, but electrical and fuel truely baffle me. Where to go from here, how to do things......I really need guideance and help.
Thank you, Brian
Thank you, Brian
