Fuel Pressure Question 1988 C4
MatthewMI
Lansing, MI
1988 35th Anniversary
Guys,
I have a weird issue with fuel pressure on a 1988 C4. Just put the car back together (it came in boxes) so it is fresh from the intake manifold up. New injectors were there when I got it, put them back in (I kno, I should have checked to see exactly what they were). New fuel pressure regulator and fuel pump/sock when reassembled as well as fuel filter. When firing, found the pulse dampener was bad, replaced with hose and was able to hold 40 LBS of pressure at the rail. It would hold the pressure for more than 30 minutes. Fired the car after an extended crank and let it warm up. Ran well. On the next firing which was cold, the crank was extended and a hard start. Checked the rail pressure and it got pressure at the 2 second prime but them bled off in 30 seconds and it seems to have a miss. Last night I had the same bleed of fuel pressure cold, started hard, miss is there still. Fuel pressure 38 LBS at idle. But, when i shut it down some what warm now, the fuel pressure stayed high... for as long as I cared to look at it.
Any ideas? Maybe the cold start valve? I neglected to clean it when I pulled the manifold (never crossed my mind) but did flush some nasty fuel from the fuel rail and lines. Maybe a sticky injector from the nasty in the fuel rail that flushed itself out while running?
I'll try to see if it holds pressure cold tonight.
Thanks!
Matt
I would chase the miss first
You didn't say if the miss was at all times, under load or just at idle
Sent from my SM-N920P using Tapatalk
The car is on jack stands but seems to be consistent as much as I can replicate in the current situation. Right in the middle of an interior refresh so can't actually shut the doors right this moment.
So here is what I pulled out of the car for a plug and what I was told should be in the car for a plug...
What a good start😀
Yes, very wrong
So, all plugs but number 8 looked ok.
8 is fouled
I pulled cold start injector and fire with injector tester, no fuel. Pulled and cleaned, still no fuel.
My my theory is the number 8 injector got a little of the nasty in the fuel rail in it. That was causing that injector to leak sporadically. It is ok right now. Then I think no fuel from cold start is causing my hard start cold / poor idle cold.
So now now the question is, can that cold start be cleaned?
The top plug in that image is a 3/4-reach, flat seat plug for L98 aluminum heads. The bottom plug is a .460-in reach, taper seat plug, for cast iron heads which were not used on Corvette after MY86.
If the car is an 88, unless it has an incorrect engine with iron heads, DO NOT use the bottom plug.
Finally, the plug you took out looks damaged. I'd replace all 8 plugs before moving on to the fuel pressure issue.
Thank you, appreciate the input. Plugs are done now, runs better warm but that cold start valve is toast. Waiting for a replacement now.
