nlreb54 said:Does anyone know the fuel pressure for a stock fuel pump on a 74 small block? I am thinking about changing the stock pump out with an eldebrock fuel pump to match the carb. :confused
Thanks!
Vettehead Mikey said:I just gotta ask- WTF will a hi-po fuel pump do for you? If a pump fills the carb bowls fast enough to avoid starvation, any extra capacity/pressure/flow will either need to be bled off, or will cause the carb to flood by forcing the float needle off it's seat.
The stock GM pumps will deliver far more flow than any street engine can use, so why bother?
I also don't understand why you guys install carbs that can't deal with the pressure from a stock pump, and then need to find an aftermarket 'low pressure' pump or put in a regulator to drop the pressure.
:confused
scroll back up to the second reply to your orignal request.nlreb54 said:I dont guess I stated my question correctly. I need to know if the stock fuel pump delivers more than 6 psi of pressure?
I would assume that the 74 would be the same as a 73. The stock pump on the 73, the factory stats shows the p[font=Arial,Helvetica]ressure range (shut off pressure at 1800 rpm) as being [font=Arial,Helvetica]7.50 - 9.00 PSI at pump outlet.[/font][/font]nlreb54 said:I dont guess I stated my question correctly. I need to know if the stock fuel pump delivers more than 6 psi of pressure?
The L81 restoration package from Chevrolet says the same thing....Tom73 said:I would assume that the 74 would be the same as a 73. The stock pump on the 73, the factory stats shows the p[font=Arial,Helvetica]ressure range (shut off pressure at 1800 rpm) as being [font=Arial,Helvetica]7.50 - 9.00 PSI at pump outlet.[/font][/font]
[font=Arial,Helvetica]tom...[/font]
