M
Mciamp99
I was wondering if someone could answer this question. Is the fuel pump set vertical or horizontal in the tank? Also is there a overheat circuit in the fuel pump? And last but not least under what conditions would the Fuel pump stop pumping even when it has power and fuel? Neither the relay nor the PCM is shutting it down, yet it quits, resets, runs and quits again. I am on my second pump and both have acted the same way. In my set up with the 75 I currently have it set Horizontal and wonder if that is contributing to my problem. Any insight will be appreciated.
