fuel sending unit help
82mystery
joelton,tn.
1982 blue
:bash I HAVE CHANGED TO A MECHANICAL FUEL PUMP AND DONE AWAY WITH ELECTRICAL PUMP AND SENDING UNIT COMBO. WHAT BOLT IN SENDING UNIT COULD I USE TO REPLACE THIS ? ALSO , I HAVE 450 HP AND WOULD LIKE TO KNOW IF THE STOCK 3/8 FUEL LINE WILL SUPPORT THIS OR GO TO A 1/2 IN. LINE . I RAN A FUEL PICKUP LINE DOWN FROM THE FUEL LID WHERE THE ASSEMBLY WENT. PLEASE HELP IF YOU HAVE HAD A PROBLEM LIKE THIS. THIS IS THE BEST PLACE INFORMATION CENTER ON THE NET BAR NONE, I LIKE THE IDEA OF DOING IT RIGHT THE FIRST TIME. THANKS LARRY
78-82 all use the same tank so the 78-81 sending unit will bolt right in.
HAVE BEEN OUT OF TOWN, I APOLIZE ON GETTING BACK TO YOU SOONER. THANKS FOR YOUR IMPUT . I WASN'T FOR SURE WHICH ONES WOULD FIT. THANKS AGAIN , LARRY
THANKS FOR YOUR IMPUT. I JUST WANTED TO MAKE SURE I HAD ALL THE BASIC STUFF COVERED. THANKS AGAIN, LARRY
