ghr4news
Happened the other day, the anti-lock light came on the information panel in the dash. My vette is a 1986 Coupe. I also noticed the A/C controller panel lights went off knocking off all A/C. Checked fuse and it was blown. Turns out that same fuse feeds the circuit for both the anti-lock light and the A/C controller. I replaced the fuse, car worked ok for a day, then when I went to start the car the next time, the fuse blew out again and once again the anti-lock light came on and the A/C panel stopped working. It blew out just after I had turned the ignition key to the "on" position, before starting the engine. Only thing I can think of that may have added to the problem is the day the fuse went out the first time, I had to use the parking brake; something I don't generally do cause one of these days I'm going to have to adjust the cable/hand grip. When I took the parking brake off, the parking brake light stayed on. I had to put the parking brake on and off again, do a hard release so lever could engage the switch that turns the parking brake light off. Could that have anything to do with it? The fuse that's blowing out is the "10-A Gauges" fuse. Its located 2nd from the top on the right hand side of the fuse panel. What's causing this fuse to blow?
Looking forward to your help.
