You won't hurt anything by driving with the bad actuators.  The dealer is quoting prices so far above ridiculous that it's not even worth laughing about.
You should be able to find new shocks inthe $250 range or you can have Bilstein rebuild your old shocks.  Actuators, unfortunately, are high-priced and availability is getting to where the prices will continue to go up.
My 92 vert had FX3 and I really liked it.  I had a shock rebuilt and replaced one actuator.  Still worth the money!!
Depending on your car's mileage, it might be worth rebuilding all 4 shocks and getting a couple of actuators.  To find about the rebuild process, call Bilstein at 1-800-537-1085 (Poway CA near San Diego) and ask for Jack French.  he can give you information on what's involved.  I had heard that Bilstein is supplying shocks and actuators for a certain Ferrari model and the actuators are supposed to be the same as the Corvette ones.  Ask when you call.
If you do decide to send them off, just buy a set of cheap shocks for a base Corvette.  When the rebuilt shocks come back, sell the cheapies on eBay.
The SRC codes will remain as long as the SRC controller and BCM sees any problem related to the FX3 system; so a bad actuator (whether or not it's even on the car) will still cause a code to be set and the light to come on even after clearing the codes.
As far as resetting the codes, the tool you need is suprising.  A
paper clip !!  Straighten the paper clip into a U shape   Turn the ignition switch to the ON position but don't start the engine.  Insert one end of the paper clip into terminal A of the ALDL.  Take the other end and insert it into terminal C for two seconds and remove it.  Repeat this two more times for a total of three times.  This resets any SRC codes.
You can use the paper clip to find any of the SRC codes or any ECM or BCM codes for that matter.  The best money you can spend on the car is for a set of the genuine GM Service Manuals.  These manuals are the same ones that the service techs have available to them at the dealership.   Go to
www.helminc.com to order a set for your car.
These manuals are written for people with some level on mechanical aptitude but they are certainly written so that you can understand the diagnostic and repair procedures.  For example, The section for the Selective Ride Control System has everything you need to know to service the system and it;s written clearly and easy to understand and follow.
