A
AIRBUS
red69coupe said:I can't believe the paper clip thing thats awsome, my shop is a small garage they are corvette specialist but they don't read the codes for the ride control So thats why I took it to the dealer and they charged me 90 bucks to tell me whats wrong with it. Thanks for the help
Does anyone know how hard it is to replace the actuators and shocks?
Just happen to know how it's done.
The fronts are easy to replace while the rears require just a bit more care.
I broke two actuators last month and got replacements from Contemporary Corvette for $125 ea plus shipping.
I sent the shocks to Bilstein and they did a totat rebuild for $100 each.
Now I know you're curious as to how the actuators got broken.
Well, during a water pump change, I had the a/c compressor removed from its bracket, which has to come out to change the w/pump. The hood fell from the full open position, knocking the compressor off its perch and as it fell it broke the actuator off the top of the rh front shock.
The left rear actuator got broken as we pulled the lh rear shock outward from its attach point at the knuckle.
Lessons learned: protect those actuators up front, especially if you've removed the center wheel tub panel for access to components. The plastic
inside that little black housing is extremely yellowed and brittle from age and all the heat in the motor compartment.
Keep that hood from falling as all kinds of ugliness can result, as you can imagine.
On removing the rear shocks, compress the shock as completely as possible before rotating the bottom end of the shock off the knuckle. This shortens the moment arm at the top of the shock so that you don't swing the actuator over against the wall of the frame and break it off.
Best of luck, Man.
