C
CEKing
Could someone tell me was the gas tank on a 1996 Corvette is constructed from? Is it steel, aluminum, an alloy, etc.?
Terne coated sheet is cold rolled sheet that is hot-dip coated with a lead-tin alloy of approximately 92% lead and 8% tin. The coating, which has a dull gray finish, is very ductile and has a lubricating characteristic that enhances formability in drawing operations. Terne coated sheet continues to be used today because of its excellent corrosion performance when in contact with petroleum fuels. The lead-containing terne coating provides long-term barrier-type corrosion resistance. Recall that barrier corrosion means simply that the liquid medium is physically kept from contacting the steel to prevent corrosion of the steel. In addition to being used for fuel tanks, terne coated steel sheet has a number of specialty uses such as oil-filter shells; most are related to terne's excellent lubricating action when manufacturing deep-drawn parts.
