I have had both senders replaced 4 times in the last 3 years. They last from 1 to 6 Mos. and then go out. I have tried Shell, Exon, and Chevron no help. At this time my car is acting up again, but now the warr is out.
schmaltzr said:I currently have a problem with the Drivers side door not wanting to unlock with the remote or the switch. It too was intermittent, but now it just quit. any ideas?
ZEDohSIX said:I also used techron to fix my problem. However I also researched and changed to a low sulphur fuel.
Many high quality fuels also have high sulphur content. The lowest sulphur content I found was in BP Ultimate which is also a high octane rated fuel. BP Ultimate has sulphur at about 50 ppm whereas most other fuels simply meet the regulations and have around 500 ppm.
So far the problem has not re-occurred. Check out the sulphur content of the fuels you use. Pick the lowest sulphur content you find and not one that just meets the regulated levels.
