Has any one with a new c-7 corvette have a problem with filling it? If i put the nozzle all the way in like they say it cuts out like it is full.i have to pull it part way out in order to fill it.
No problem with filling my C7 Coupe - nozzle shuts off when full. May want to visit the dealer if problem continues. Also, go to the Stingray Corvette Forum and check their postings - if it is occurring with others, then they most likely will have a thread on it.
I've heard that the C7s like you to pump the gas without using the on-lock on the nozzle. A little variation of the flow seems to keep the auto cutoff from stopping the flow.
I have had similar problems. What I have found is if I insert the nozzle all the way in and let it hang, it seems to be fine. If I hold it upright, it kicks off like it is full. Took some frustrating moment to notice the difference.
